Renovation sofa imitation leather by cast
I followed your recommendations to renovate a chocolate "By Cast" imitation leather sofa with a cleaning step and a step of applying a colourless protective coat with a roller. This sofa had no holes, but wear and tear on the surface with a sticky/sticky appearance when you sit in it in the most stressed areas.
The result: the surface sticks less when you sit down, but still sticks a little and the protective layer has left in places in the form of more or less large blisters. Photos are available.
Please indicate a procedure to me to achieve a better result.
You have proceeded as follows, please list precisely the steps of your renovation.
The SOFOLK team
I simply cleaned the whole sofa with a microfiber and the leatherette cleaner you offer. I waited 24 hours to dry and then applied the imitation leather protection product you sell (order N BDC10722) to the roller, and I removed the bubbles when applying it by ironing the roller 5' after a first pass. I let it dry 48 hours before use. Is my substrate sufficiently cleaned before application or do I need an additional treatment in the most worn areas or a second protective layer for the areas where it still sticks a little?
The very worn parts would certainly have required a re-colouring, apply a 2nd coat will be better. For areas that stick a little, do not hesitate to degrease again.
The SOFOLK team
The SOFOLK team
after light sanding and cleaning with your product and then acetone the appearance in places is very rough and there are "stains" of non-uniform color. Is it necessary to do a recolouring before applying the colourless protective layer? What a procedure and products.
I have the ref of the sofa for the chocolate brown color
Attached pictures
I didn't get an answer to my last request and the last photos sent with acetone degreasing. I think I need to do a re-colouring before applying the protective coat.
Here are the ref:
Twist sofa 3 pl in bycast leather
Collar 01380/57350
Year 2003
(It's dark brown, chocolate)
Thank you for making me a price offer.
Fluorescent yellow reclour
Par Jackthesuit, le 09/03/2023
Boat stevedoring
Par Claude, le 29/08/2019
Repainting the benches of my catamaran
Par Cata83, le 23/09/2018
Re-colour a new leatherette bench
Par Sheldin', le 14/12/2017
Par Kourpavix, le 16/10/2017
Boat linings
Par Acetabulaire, le 25/09/2017
Renovation of boat seats
Par Karacoli, le 02/07/2017
Motorcycle saddle
Par Steph, le 26/03/2017
Renovation of the boat bench
Par Jean-Louis, le 02/09/2016
