Colouring of the leatherette and protection
Hello, how long should I wait between 2 coats of recolorant and how long should I wait between 2 coats of protection. Because your notice is not very clear on this subject thank you
You can accelerate the drying with a hair dryer and in this case it takes 5 minutes between coats and as soon as the re-colorant is dry, you can pass the protection by activating the drying as well, otherwise you have to wait until the re-colorant layer is dry, you can see it to the touch, and wait 24 hours to pass the protective varnish. we will repeat the instructions for use.
Sofolk
Par Sofolk, le 10/11/2017
Alcantara dye ordering
Par Sandman, le 13/12/2024
Dying colours for alcantara
Par Naomi, le 29/12/2023
Dyeing alcantara car seats.
Par Rob, le 14/03/2023
Par BMW 325, le 08/09/2020
Par Small, le 17/09/2019
Damaged skai ds3 racing seats
Par Pierre73, le 08/08/2019
Par Quentin.98, le 27/06/2019
Par Jerome29, le 09/04/2019
Par Loulou38, le 28/05/2018
