Sebum
Hello, my club chairs are damaged by the sebum of the skin, what to do, it's sticky and unpleasant, thank you
pascal
The first thing to do is to clean, it is necessary to extract from the leather the sebum that will eventually weaken the leather until it causes cracks, you have the Detachment Cleaner which is the best non-discolorant cleaner that exists for this problem.
https://www.renovation-du-cuir.fr/fauteuils-club/fauteuil-club/nettoyage_19.html
Then you have two solutions with or without recolouring depending on whether the leather remains a little black after cleaning. We will explain this second step to you.
First smooth the leather with fine sandpaper, then apply two or three coats of Pigment Recolouring and finish with tinted wax, apply tinted wax all over the chair to even out the colour.
Thank you, but how do we identify the firing device?
For the colour, either we send you a colour chart, or you cut a strip of leather inside a cushion at the zipper or you take this piece under the sofa after removing some staples from the clean cloth.
it's a WOOD ROCK leather... I'm really disappointed, it was shiny and became matt and sticky on contact with the skin.
So it is certainly a pigmented leather, in case your leather is not dyed sheep basane the process is not the same... We think you should call us to be able to advise you well.
Renovation of 4 club chairs
Par Virgile69, le 26/08/2019
Club chair catering
Par Felip76, le 17/05/2019
Par Mag_leb, le 09/04/2019
Club chair renovation
Par Oladys74, le 27/03/2019
Very worn out club
Par Angélique, le 17/03/2019
Club armchair catering
Par Betty, le 17/03/2019
Cracked and torn leather
Par Mel44, le 23/01/2019
Par Sylvie 32, le 13/12/2018
Par Liodave, le 20/11/2018
Club abimé
Par Linou, le 01/10/2018
