Stressless
I would like to renovate a stressless purchased second-hand and not maintained for 10 years.
Sincerely,
Here are the pictures of the chair
Please send us some pictures.
Sofolk
You will have to recolour because the leather needs a paste repair, we recommend the leather renovation kit 1 armchair
https://www.renovation-du-cuir.fr/en-gb/leather-sofa/kit-renovation-cuir-1-fauteuil-ou-4-chaises--ki1f.html
we will add 1 can of sebum cleaner, we remind you in the comments of the order
Sofolk
Thank you for your answer, I will place the order.
Do I have to choose the color for the recolorization right away?
PS: the technical problem was due to the fact that the computer was updating, it works much better now!
Order placed.
We have received the schedule and are leaving on black.
On the other hand, we have just seen a crack on the seat (holes had already been identified on the armrests); the leather is very damaged and is starting to "tear" (see pictures).
How to proceed to repair and consolidate these cracks?
I read that it was necessary to glue a piece of fabric or leather under the crack and then repair. Is that correct? What tools/products are needed for this?
And at what stage should it be done (after cleaning?)?
Thank you in advance,
Below are pictures of the cracks on the seat and armrests:
We will provide you with leather pieces to slide under the envelope between the foam and the flesh side of the leather, you will glue them with the paste. For the seat it is necessary to open the tear in order to glue a piece that will pass from the other side of the seam, you will have to glue a part to the neoprene to match the seam bead, to finish level the cavities with paste. In case of difficulty, do not hesitate to call us.
Sofolk
Dying a natuzzi sofa
Par Bill, le 15/01/2024
Par MAX B, le 17/08/2020
Change of colour of sofa
Par Kd, le 14/10/2019
Stained leather renovation
Par Alain, le 09/10/2019
Renovate sofa
Par François, le 30/09/2019
Par JEAN-LUC38, le 01/09/2019
Sticky leather sofa
Par Freddy, le 24/08/2019
Par CAROLINE62, le 20/08/2019
Par Ana, le 16/08/2019
Leather salon repair advice
Par BARBARA60, le 15/08/2019
