Sticky re-colouring agent
I wanted to ask you if it is normal that following the use of the leather renovation kit on my sofa, the appearance is very good but the repaired parts are a little "sticky".
Note that this is the second time I have used it and the result is always the
same.
Is there anything else we should do?
If the recolouring agent is a little sticky and gives the impression that it never dries, it comes from the substrate which has not been sufficiently degreased / prepared.
Our products are water-based. If the substrate contains traces of grease, it will prevent it from fixing properly.
The only solution is to start over, and clean the acetone support thoroughly.
If it is a sofa, it is possible that the sebum is the cause of the problem (mainly in the neck and armrests). Sebum is not always visible and is difficult to remove. If you think this is your case, it is better to use our sebum cleaner several times before the acetone to avoid damaging your leather!
Tengo este problema después de aplicar el tinte..
He seguido los paso:
-lijado de todo el sofa
-limpieza por dos veces con acetona
-reparación de grietas
-aplicación de tinte por todo el sofá con rodillo de espuma, tres capas.
Han pasado 48 horas y antes de aplicar el barniz me he dado cuenta que está todas las partes pegajoso como si no se acaba de secar. En una zona he aplicado el limpiador detachante y todavía queda más pegajoso.
a que se refiere con empezar de nuevo?, hay que retirar el tinte aplicado por completo?
Hay posibilidad que dejando pasar más tiempo llegue a secarse?
Dying a natuzzi sofa
Par Bill, le 15/01/2024
Par MAX B, le 17/08/2020
Change of colour of sofa
Par Kd, le 14/10/2019
Stained leather renovation
Par Alain, le 09/10/2019
Renovate sofa
Par François, le 30/09/2019
Par JEAN-LUC38, le 01/09/2019
Sticky leather sofa
Par Freddy, le 24/08/2019
Par CAROLINE62, le 20/08/2019
Par Ana, le 16/08/2019
Leather salon repair advice
Par BARBARA60, le 15/08/2019
