Hello
I just bought a lounge set composed of a 3-seater sofa, a 2-seater sofa and a Ligne Roset brand pouffe that I want to detach and give it back a little color without necessarily removing the patina side that suits it.
The leather is in a super condition, well thick, smooth and always very soft. The stains on the seats are small and few in number but scattered all over the place. The latter come mainly from food (fat, ice, yoghurt...). A much larger stain (diameter 20cm!) comes very likely from the head of the former owner who used to always sit in the same place to watch TV, so probably a sebum stain from the scalp.
I attach some pictures to help you visualize what this set looks like.
http://i39.servimg.com/u/f39/15/86/30/71/dscn6611.jpg
http://i39.servimg.com/u/f39/15/86/30/71/dscn6612.jpg
http://i39.servimg.com/u/f39/15/86/30/71/dscn6613.jpg
Can you please tell me the treatment to be given to him as well as the quantities of product to order?
For information the dimensions are as follows:
- Large sofa L224 P99 H82
- Small sofa L189 P99 H82
- Ottoman L72 P72 H41For the color I think I get for reference 314
Thank you very much.
Gffy
Good evening
First of all a big thank you for your very quick and complete answer.
If I understand correctly, the following products are to be used in the following order:
1 - Sebum cleaner to remove the stain (4-5 passes)
2 - Degreaser, leather stripper (1 pass)
3 - Pigment re-colouring agent in 2 layers
4 - Silky leather varnish (1 pass)
The 125ml sebum cleaner is included in the renovation kit you specify. Is it necessary to order another bottle separately in addition, or is the 125 ml kit sufficient?
Thank you. Thank you.
Sincerely,
Gffy
The 125 ml can of sebum cleaner is sufficient.
You have summarized the steps of the renovation well except that before passing the cleaner stripper it is necessary to sand lightly the seats and armrests (the sandpaper is provided with the kit).
Sofolk
After having made the first sofa in July I started today to re-colour the second sofa. The new can of the pigment dye used was still sealed as a book, however, it has a dry (but still applicable) and has a very strong smell of'well made cheese'. Is this normal? Can the product still be used without compromising its durability?
Thank you for your feedback
Gffy
Gffy
Hello, After having made the first sofa in July I started today to re-color the second sofa. The new canister of the pigment dye used was still sealed as delivered, however, it has dried (but still applicable) and has a very strong "well made cheese" smell. Is this normal? Can the product still be used without compromising its durability? Thank you for your feedbackGffy
You can dilute with a little water, the product will hold without problem but it is unpleasant to apply. Do not leave the products for too long in the heat, even in a firm can. If you have a color of the color chart we can replace it.
Sofolk
Thank you very much for your quick feedback, it is very appreciated, if the product's performance is not compromised, I will apply it like this. Thank you again Gffy
Finally I couldn't paint the couch. The pigment dye is too dry even when diluted with water. That makes "lumps", I preferred to stop. If your replacement offer still stands, it would be with great pleasure. Gffy
Hello, I had modified the colors following receipt of the color chart. In this case it's the green 349 I would need to make my 3-seater sofa. Thank you very much.
| OTHER SIMILAR TOPICS | |
| Leather cracks sofa
Par Elita, le 16/12/2025 |
| Pulverizer included?
Par Magnus Rivus, le 05/12/2025 |
| Dying a natuzzi sofa
Par Bill, le 15/01/2024 |
| Sofa green colour with light black effect
Par MAX B, le 17/08/2020 |
| Change of colour of sofa
Par Kd, le 14/10/2019 |
| Stained leather renovation
Par Alain, le 09/10/2019 |
| Renovate sofa
Par François, le 30/09/2019 |
| A leather living room to be completely redone
| Sticky leather sofa
Par Freddy, le 24/08/2019 |
| Repair of large chesterfield leather hole
